![]() | Home > Technical > Altimeter |
M@verik Member Since: 16 Aug 2005 Location: Somerset Posts: 130 ![]() ![]() ![]() |
Has anyone found out if there is a means of calibrating the altimeter function in the Off Road Navigation?
Ecosse Member Since: 08 Jun 2005 Location: Grampian Posts: 12 ![]() ![]() |
Unfortunately it is a known defect in the sat nav system used in the D3 & RRS. I have a detailed technical explanation from LR somewhere, but basically the system would have required a 3rd set of calibration/inputs to be able to provide accurate altitude readings! - and guess what the system (which is made by Denso) hasn't been specified with them!! Mine has been checked over by both the factory & Denso's own technical guys and they claim there is no way of fixing it!! |
RRUK - thanks but with respect if you believe that, you've been listening to too many of the less well informed Landrover dealers who have been slated elsewhere, the ones that fob you off with any old guff that is.
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 ![]() ![]() |
I have noticed this, we were sat on the beach at Blackpool and the altitude was showing 250 feet. Somebody needs to tell my car that its wheels were in the sea. Should have been a below sea level reading |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
I wasn't going on anything someone had told me Maverick, merely my own summation from experience. ![]() My only question would be, what does it really matter how high above sea level you are? In normal UK driving when does this really bare relevance in terms of plotting Sat Nav routes etc? Personally, it doesn't matter to me, never has and never will. The only time altitude has every been on interest is when I am at 35,000 feet in Business Class or ontop of a mountin of snow on a ski holiday! ![]() My observation is that there is a lot of negative comments concerning the Nav system in the D3 and RRS, it may not be bleeding edge but compared to many systems it's fine and capable and does what I need of it. Let's hear some positives for a change! L319 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
what I can't understand is what is the point of equiping the sat nav system with an altimetre that doesnt work? If you are unable to adjust it or it doesnt show correct readings..... its pointless and need'nt be there at all. |
I agree if its fitted it should work correctly. ![]() |
You might be better off packing your trusty sextant ....Cpt J Cook never had any bother with his.... |
And look what happened to him on February 14, 1779 ..... . ![]() ![]() If only Cook had a reliable and accurate sat nav system to help him find that darn stolen boat .... ![]() ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
My SE doesn't have the nav system but what interests me is what it tells you if you go offroad and into the wilds, can anybody tell me? I have 2 systems available on my Ipaq PDA with GPS - Navman for point to point with voice directions for on-road use and then I have the Memory Map Navigator Digital Ordnance Survey maps for the entire UK also loaded on an external memory card (3 Gbytes of memory are required for the maps so I have a 4Gb micro drive). The MemMap system can be stablised with the car in the centre of the screen and the map scrolls along as the car moves and also a "track" line is drawn on the OS map, what it cannot do is give you voice directions to your destination, but at least you can read the maps either as a UK road map or an OS map with all the usual detail and see exactly where you are.
