Home > Faults & Fixes > Engine System Fault, disconnected turbo air hose - SOLVED
GunnerBill
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
I'll edit this post because I fixed the problem.
2008 Sport HSE 2.7 TDV6
I had an "Engine System Fault" message. Which put me into a limp mode. After checking under the bonnet I found that the cowling that covers the top of the radiator and takes the air hose from the Air Filter Box / MAF sensor to the turbo was loose and that it had popped off the seal stack that joins it down on the right side of the radiator.
Hose disconnected here:
The two connections:
Seal:
Air box / MAF at the top, turbo side connection at the bottom:
Tie-Wraps replaced the broken clips and now hold it firmly in position.
I've made a couple of test drives and no recurrence of the fault.
Post #585202 Sun Aug 11 2019 12:26pm
get the code read
or buy yourself a code rear. (which range from £10 to £450)
Post #585206 Sun Aug 11 2019 3:05pm
