Home > Wheels & Tyres > tyre size probs
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
should be obvious: you travel less miles on speedometer but use similar fuel = less mpg on the computer, not in real life.
Post #585007 Mon Aug 05 2019 10:14pm
When I fitted 275/45 x 20's I found the speedo reading to be more accurate as well, as for mpg the trip computer is so inaccurate anyway I totally ignored it. 275/40 x 20" and 255/50 x 19" were the only factory size/option fitted to the facelift RRS1, the preface-lift did have 17" and 18" option I believe for certain markets, the different tyre/wheel sizes although different the overall diameter/radius will be approximately the same, so imagine there is no need to have to have a selectable different speedo setting for every wheel size.
Post #585008 Mon Aug 05 2019 10:26pm
rover75
Yes you should really do your own calculation from refill to refill, saying that mine is not far far off. on 275/40/20 atm.
Post #585009 Mon Aug 05 2019 10:47pm
If anybody runs a S/C and worried about fuel I think they have the wrong car Rolling with laughter
Post #585010 Mon Aug 05 2019 10:55pm
rover75
I'm not, ru? at the moment it's saying 3.4 km to the liter - know it can do better but hey it's summer with beaches etc.
Wouldn't touch a derv with a barge pole. had one in my life, 1 too many.
Post #585011 Mon Aug 05 2019 11:04pm
Anno43
Thanks for pointing out it was obvious Rover, it’s what I figured and I’m not worried about the cost per mile just the change and wanted the confirmation. Thanks again
Post #585045 Tue Aug 06 2019 9:43pm
rover75
Drive on -
Post #585046 Tue Aug 06 2019 10:25pm
