Home > Off Topic - Other Cars > New Defender shot maybe
Page 9 of 14 <123 ... 8910 ... 121314>
BKHK
As often happens, the initial shock of the looks gradually grow on me. Having watched and read the reviews, I think this could cannibalise sales from all other JLR vehicles. It will smash Disco sales except for the 7 seaters. It will take some sales from the RRS and even FFRR simply because it will achieve “cool” status for quite a while. FFRR is starting to look really old now.
I am not really an SUV or 4x4 fan anymore since it’s really only me in the car these days. But if I wanted one (and it’s tempting) I would go for a used G55 with the side exhausts! Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #597118 Sun Mar 29 2020 12:49am
Post #597120 Sun Mar 29 2020 7:28am
Reviews from Car & Driver and Flat-Out Magazine:
Post #597121 Sun Mar 29 2020 7:37am
?t=741 --
Post #597123 Sun Mar 29 2020 8:24am
Review from an Oz off-road mag: https://www.unsealed4x4.com.au/does-the-al...-find-out/
"Where The All-New Defender Stands Out
When the terrain gets rough, the 2020 Land Rover Defender rides better than any other stock 4WD I’ve tested, over almost any surface. It’s better than segment competitors like the Jeep Wrangler with its softly-sprung solid axles, and it’s even better than the desert-bashing Ford Raptor and its three-inch diameter Fox internal-bypass shocks. ...
That impressive ride quality sets the rest of the tone for the all-new Defender—it’s perhaps the most-comfortable way to travel off-road in mildly technical terrain. Performance over undulating boulders and rocks is impressive, with the suspension reacting hundreds of times per second to the current conditions. The Defender is nothing less than surefooted and inspires confidence in everyone from the most-novice weekend warrior to the professional off-road driver; though those with more experience may find the driving experience a bit more “digital” than they’re used to. ...
Where We’re Concerned
Historically speaking, Land Rover doesn’t have the best reputation for reliability, but it is important to know that aside from a few pre-production issues I experienced, the Defenders I personally drove in Namibia gave me zero reason for concern. Reliability on the other hand is something that has to be earned with time, so I cannot comment on that. It is worth noting that as a brand Land Rover is much more reliable than it used to be, currently echoing the golden era of reliability for Toyota, according to America’ Consumer Reports. ...
Proving Its Mettle (Dirt Road Performance)
... On a closed course section of Namibia’s finest corrugated gravel, we were cruising near triple-digit speeds while having a casual conversation about our jet lag; at which point we decided it was best to slow down as neither of us could tell an Oryx from a Kudu, and when they say road hazards are real in Africa—they mean it. The speed and comfort in which you’re able to cover ground in the all-new Defender is unprecedented. Modern day explorers who find themselves on rugged dirt roads in the middle of nowhere more than they do the Rubicon Trail need to take note of the Defender. Hands-down, it’s the most comfortable way of getting from A to B in the backcountry.
Van Zyl’s Pass (Technical Terrain Performance)
... The Defender’s traction control is class-leading, minimally intrusive, and quick to react, thanks to the the now customisable Terrain Response system that allows you adjust everything from steering feel to throttle sensitivity. Sure, you can’t go and tell the system to completely lock your differentials, but in my opinion, that binary school of thought is out-dated. What if I don’t want my differential completely locked because I want to be able wiggle my way through obstacles and actually be able to turn? ...
Within less than a hundredth of a single wheel rotation, the Defender’s traction control system was able to apply brake pressure to prevent wheel spin and enable traction on the more challenging sections of Van Zyl’s Pass. Terrain Response communicates with the suspension which is capable of both cross-linking the airbags to allow it to function as if it had a solid beam axle—another reason the Defender is so sure-footed.
Overall, the Defender exceeded my expectations on technical terrain, but let’s be realistic, if you’re buying a new vehicle for the sole purpose of turning it into a rock crawler, you’re going to, and should, buy a Jeep Wrangler. If you’re an explorer who doesn’t want to turn back when the going gets rough, then the Defender is all aces.
Skeleton Coast (Mud, Water, Sand)
... You couldn’t imagine a worse environment for a pre-production vehicle, especially a Land Rover Defender. Dust. Mud. Sand. Water over the hood. Repeat. We would be wearing all of them in triplicate had we been in a classic Defender. We must have had over a hundred water crossings that day, and let me tell you that the Defender didn’t have a single issue. Sure, we had to pull out the winch, we had multiple tire failures, and we lodged a rock in the brake caliper. But it was real four-wheel driving—this is the kind of stuff that is supposed to happen. ...
Frankly, I’m surprised we made it through them all, the Defender really has the capability of putting power down in a controlled way that few other vehicles can match.
Somewhere in the Hoarusib River Canyon, a place I never thought I’d be, driving a vehicle I never thought I’d see, the all-new Defender finally made sense to me. It isn’t supposed to be a replacement for its former self. It’s supposed to be an all-new vehicle for an all new world—for an all-new buyer.
The only thing that remains the same? There’s no finer way to travel the world than behind the wheel of a Land Rover Defender.
Should You Buy It?
If it turns out to be reliable, I can’t think of a vehicle I’d rather take on a legitimate expedition. It is powerful, comfortable, and depending on the engine selected, economical. While there are more time-tested vehicles available, none would be able to get the job done with a better balance of efficiency, safety, and comfort, while carrying more than anything else in its segment." --
Post #597177 Tue Mar 31 2020 8:16am
BKHK
Amazing how a free jamboree elicits positive comments. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #597221 Wed Apr 01 2020 1:00pm
Yes, it could all be smoke blown up LR's backside. Or it could actually be a very good vehicle. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #597222 Wed Apr 01 2020 2:10pm
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
BK Shocked off to defender2.net with you.. Laughing Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #597233 Thu Apr 02 2020 1:57am
BKHK
It looks good Zilchy, it could be better than all the other JLR vehicles. Mild V8 version would be nice. If it’s as good as they say, it might be back to the spirit of the original RR? Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #597257 Thu Apr 02 2020 1:31pm
Zilch
i hear there is a LR review of the SDv8 platforms being announced, not sure about the petrol v8's mind you.
The straight six petrol turbo with MHEV seems reasonably grunty enough.. Another Pommie Bar Steward down under
Post #597272 Fri Apr 03 2020 1:31am
Post #597275 Fri Apr 03 2020 8:04am
Tim in Scotland
I posted an article from this weeks Autocar here https://www.rrsport.co.uk/forum/topic55999.html 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #597281 Fri Apr 03 2020 9:18am
Zilch
Thumbs Up Another Pommie Bar Steward down under
Post #597316 Fri Apr 03 2020 11:12pm
Post #597375 Sun Apr 05 2020 7:20am
Tim in Scotland
Do I get the feeling he’s maybe just a wee bit bitter not to have been invited.............. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #597381 Sun Apr 05 2020 10:22am
