Home > General > High coolant pressure
geoffsnook
You sure your fan is working correctly know Disco's have issue's with the viscous fan Thumbs Up
Post #595299 Fri Feb 21 2020 12:31pm
loonyball
United Kingdom 2007 Range Rover Sport TDV6 HSE Rimini Red
An update on my coolant issue with my car, i was talking to an ex jlr technician yesterday and explained my symptoms, he suggest i remove egr pipes going to the throttle body and check for water,
Sure enough, i removed the pipes At the throttle body end and drivers side is dry as snuff, passengers side wet, slightly sludgey.
I’m now wandering could a failing egr/cooler have been the issue all along ??
Post #598442 Sat May 02 2020 10:44pm
Disco3potato
South Africa
Did you ever resolve your issue?
Post #615881 Sun Jul 18 2021 9:12pm
