Home > Maintenance & Modifications > Tired DSC/ACE dampers- service or replace?
Page 1 of 4 1234>
PompeyDave
Hi all, I've got a 2010 3.6 V8 in Stornoway with 103k on it. It has full LR history and is in fantastic overall condition, but I do have a really wallowy, bouncy ride that just doesn't feel right. It has the DSC or ACE stability control system. I understand that the fluid and filter can be replaced, but does this sort the issue? I would have thought that once knackered the dampers are just that- knackered, and will require replacing. West 4x4 who serviced it last noticed that the ride wasn't right, but we didn't have time to look into it any further on the day. The air bags are good all round as is the compressor. Do I just need to do the fluid and filter service, or do I replace just the dampers and re-use the bags, or am I looking at four new DSC/ACE struts, and if so any ideas on cost? Thanks in advance.
Post #581844 Tue Jun 04 2019 5:47pm
Brit Plumber
Not sure you have the right idea behind ACE and DSC what happens if you put the car in Dynamic? Does it improve? It should become firmer in the corners and give a stiffer ride. With it off mine willows a little but not badly. I don’t think it would help with a bouncy ride as it’s not really designed for that purpose.
If you do a DIY fluid change it can be a ball ache getting the shields off and you may need to make/buy a kit to do it. There is the alternative which is swop the oil over and over again till you’ve done 90% or so. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #581901 Wed Jun 05 2019 7:28pm
shepp
Brit, yours probably has continuous variable damping, my old sc didn't have it, and was slightly firmer. My 2012 has CVD damping (vast improvement on old dampers)and sometimes feels slightly spongy until I apply dynamic. (It definitely improves cornering)
Dave, it's Probably worth checking if you have CVD dampers ( has a cable attached to the top of the damper.
The ace is only applicable on cornering or off-road, it should not make the vehicle bouncy. Check the dampers the old fashioned way, bounce the corners and see if it recovers immediately. MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #581904 Wed Jun 05 2019 7:59pm
knwatkins
At 103k, I'd imagine you would benefit from a new set of dampers. My 2010 has done 98k now and I noticed the ride was a bit bouncy so I installed new Dunlops on the front and wow! What a difference!
I've now bought another pair for the rear that will be going on this weekend...
 Kev
Post #581911 Wed Jun 05 2019 9:17pm
Brit Plumber
Yes mine has the CVD but I drive it in Dynamic quite a lot as I prefer the harder cornering for Lincolnshire roads. My car definitely has 3 lives, Dynamic off and Drive selected gives a restrained/relaxed drive, Dynamic ON and Drive gives a firmer deal with a little more poke but with Dynamic ON and put it in Sport, the beast awakens. 2019 5.0 SC SVA (Current)
Post #581919 Thu Jun 06 2019 8:21am
PompeyDave
Hi guys, yes I have the CVD dampers as I have a cable at the top of each one. Am I getting confused with something else here as in the fluid and filter replacement is clearly for a hydraulic system, whereas the cable is an electrical circuit? The hydraulic system is the DSC/ACE, yes?
Either way, at 103k the struts would appear to need replacing. I've looked at Arnotts but threads on other forums seem to suggest the strut itself is only checked and they just add a new bag- hardly confidence inspiring. If I go for OEM struts where's the best place to get them for a good price? Island 4x4 seem to come up a lot on the U.S. forums.
Post #581935 Thu Jun 06 2019 5:31pm
Advanced Factors. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #581941 Thu Jun 06 2019 7:52pm
knwatkins
I got my Dunlops from Craddocks for:
£139+VAT for the fronts
£150+VAT for the rears
I buy from forum sponsors when they are cheaper, but they were significantly more expensive when I checked them out. Kev
Post #581943 Thu Jun 06 2019 8:51pm
knwatkins
Yes, you are correct. From memory, I think the filter and fluid needs doing on the hydraulic ARBs every 75k. It's a simple enough job...
I'll be doing mine in a few weeks time. Kev
Post #581944 Thu Jun 06 2019 9:02pm
He asked about OEM. Dunlop aren't OEM so they will be cheaper. Also his are variable dampers and I'm betting you didn't get variable dampers + airbags for the price you quoted. 2012 SDV6 - it's missing a couple of cylinders
Post #581946 Thu Jun 06 2019 10:43pm
knwatkins
Correct.
I'm just saying that the Dunlops were very much more expensive at AF....
For the fronts: £139+VAT (JC) vs £170.15+VAT (AF)
OEM or not, it's always worth shopping around Wink Kev
Post #581947 Thu Jun 06 2019 10:50pm
PompeyDave
Looks like the cheapest option is a Chinese set of four at £948 inc delivery via eBay. Hell of a gamble though as they could be useless, or they could be very well made. If I went for Arnott versions they'd be reasonably priced but only if you order and have them delivered in the states. Hmmm, this isn't going to be a cheap fix!
Post #581948 Thu Jun 06 2019 10:54pm
knwatkins
I wouldn't take the chance. I would always recommend buying good quality, known brands for aftermarket parts, especially suspension components.
You can buy OEM parts from LR Direct for the following prices for your model:
Fronts: £321.52+VAT
Rears: £356.84+VAT
One thing to note on OEM parts is that they aren't necessarily the actual parts that were fitted to the vehicle originally. For example, the original units on the non-CVD dampers were manufactured by Delphi. AF are advertising BWT manufactured units as OEM.
Edit: Island4x4 are actually a bit cheaper on the rears at £350+VAT Kev
Post #581949 Thu Jun 06 2019 11:15pm
PompeyDave
Ok, cheers Kev- I can't see those parts on the LR Direct site- do you have part numbers or links I can search by? Thanks.
Post #581950 Thu Jun 06 2019 11:25pm
knwatkins
Sure....
Your fronts are: LR052867 (LH & RH)
And your rears are: LR032651 (LH) and LR032652 (RH)
 Kev
Post #581951 Thu Jun 06 2019 11:32pm
Page 1 of 4 1234>
