Home > General > Wynns Formula Gold diesel treatment |
Remember 2T is designed primarily for air-cooled engines that WILL operate at higher surface temperatures than a water-cooled 4stroke diesel. Since it survives these temperatures it will be evident in the exhaust and could therefore reduce the life of a DPF. |
Tue May 28 2019 7:12pm |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
Something to bear in mind tho' is that Two Stroke engines incl. outboards/strimmers/Motorycles, usually run as rich as 50:1 ( My Yamaha outboard runs at 100:1).
Wed May 29 2019 6:52am |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 |
a 90 page thread on 2T 😁 ! Opinions vary clearly...
Wed May 29 2019 7:38am |
200:1 in 82.3litres (Disco3/4 tank) is 0.4litres of 2SO per tank.
Wed May 29 2019 9:01am |
Thought one or two of you might enjoy a little bed time reading
Wed May 29 2019 9:17am |
Agree totally. 2011 MY D4 HSE Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol. Bikes! KTM, BMW, British, Classics and others. |
Wed May 29 2019 9:45am |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
The YouTube channel Project Farm has done some fascinating analysis in fuel additives if you have a rainy Sunday afternoon.
Thu May 30 2019 5:28am |
So what happens if you overdose on the 2T ? |
Thu May 30 2019 7:53am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4980 |
A small overdose isn't a bid deal.
Thu May 30 2019 11:04am |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
It’s pretty difficult to overdose by any significant amount. If you put a litre in per tank full you really wouldn’t notice, except the small increase in cost. In the thread mentioned a member put some petrol in his tank in error, rather than drain it he filled up with diesel and a couple of litres of 2SO. All was fine. Personally I wouldn’t have done that but it worked. The ratio of 200:1 is a guide not a rigid rule. In countries where diesel quality is dodgy people put more 2SO. Someone earlier expressed a concern about DPFs. If you have one, and most people do, then you should use 2SO at the standard JASO FC, its on the bottle. If no DPF you can use JASO FB - it’s cheaper. |
Thu May 30 2019 11:42am |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 904 |
Well, Yamaha Fan convinced me, 2 stroke is in & early results are:-
Fri Jun 07 2019 11:51am |
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 |
I use Lucas Oil Addtives and Injector Cleaner MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
Fri Jun 07 2019 2:39pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
I've been using Redex diesel additives for the last year or so based largely on the fact that they've been going a long while (like Wynns) and thought I noticed a slight improvement in mpg. I use it at every fill up and buy it in Tesco when they have it on offer at £2 per bottle (which does two tank fulls) so £1 per tank full. Only time will tell if I have made any difference (better or worse) - currently on 87500 miles.... Robin
Sat Jun 08 2019 1:33pm |
nobby Member Since: 02 Mar 2016 Location: Malvern Posts: 33 |
i concur with Eaters, i do exactly the same and my RRS has completed 144k miles (400 miles a week)and the engine purrs beautifully, no issues at MoTs and fuel consumption has been steady. I use Redex and Wynns pending on deals available ever snce I took ownership nearly 4 years ago |
Sat Jun 08 2019 7:46pm |
