![]() | Home > General (L494) > DAB radio issue |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Are you sure it has dab fitted, in Australia it wasn't fitted to my 2017 RRS SE, only AM and FM.
Fill in your profile to help us help you if we know what you have it will help |
Aguiness Member Since: 31 Dec 2018 Location: Stirling Posts: 49 ![]() ![]() |
Hi
Would have thought your car should have it as most cars from Xs and above from 2009 had it fitted |
I picked the car up on Saturday just getting to know everything but there is no Dab button I will contact the dealer and ask I assumed there would be a reset settings or something similar to try that it’s not a major issue the car is fantastic |
GregP Member Since: 21 Jul 2017 Location: Gosford Posts: 52 ![]() ![]() |
Hi Aguiness,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5033 ![]() ![]() ![]() |
Yeah, according to the RRS2 brochure I looked at DAB is standard on all UK spec. variants. Don't know about Oz, but so far behind here it doesn't work anyway. Cheers Col |
Yes, we are way behind here too. DAB+ is available in the main cities only. I live in Gosford, which is in the 9th largest urban area in the country, and DAB radio for this area is not even on the 5 year plan, and the so-called 'roll-out' has been going 10 years already . Simply woeful. I have to use internet radio streaming services instead. MY15.5 SDV6 HSE Dynamic without the H . Yulong White |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 ![]() ![]() ![]() |
It's patchy across chunks of Scotland. Always fades out at top of Soutra hill heading south on the A68 for example whereas fm or in an emergency am work fine. |
