Home > Technical > RRS tdv8 rear brake shoes help
RRSV8
Hey guys
In the process of changing rear discs/pads on my 2007 tdv8
& have noticed there is no brake shoe adjuster on n/s/r
Couldn’t see anything through inspection hole
Managed to remove disc but nothing there
Is this normal or are they supposed to be adjusters on both sides ?
O/S does have adjuster thanks in advance.
Post #581259 Thu May 23 2019 6:49pm
Both sides should have adjusters. Whistle
Post #581261 Thu May 23 2019 7:52pm
Brit Plumber
Begs the question, if you don’t have an adjuster present, what is there to hold it all in place?
The left should be towards the bottom and the right towards the top. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #581271 Thu May 23 2019 10:51pm
RRSV8
Thanks for reply lads, yep very strange why adjuster is missing on one side
everything else looks ok, so have ordered new adjuster
will i have to dismantle all components to fit adjuster or will it slide in ?
thanks
Post #581436 Mon May 27 2019 5:14pm
Should be able to slide it in. With luck. And force
Post #581437 Mon May 27 2019 5:17pm
RRSV8
cheers Andy Thumbs Up
Post #581441 Mon May 27 2019 6:22pm
