Home > Technical > suspension won't stay locked in access mode
holland389
France
L320 2.7, 2006, The car drops down into access mode, the locked light is on, but it immediately resets itself i.e. it squats but then goes back up to its normal height. Where do I start?
Post #581152 Tue May 21 2019 8:09pm
Father Jack
Does this happen every time and at all locations ? My drive has a steep slope so depending on how I locate the car on it, sometimes it will spook it into thinking it is grounded or in danger of grounding and it will lift the car. I am assuming there will be sensors linked to the system so if yours does this all the time and anywhere or on any surface, you may want to ask your local indy to give your system a one off healthcheck and to look for any associated fault codes stored by your car to narrow down the cause.
Post #581159 Wed May 22 2019 7:03am
Brit Plumber
I also find it can be funny if it’s in park with the park brake on. If I remember, I select access when just finishing my journey or else I put in neutral with the park brake off and let it roll back a little to help the suspension settle. Works 95% of the time when I get the extended mode message after access mode selection. Sometimes it just doesn’t like it!! 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #581164 Wed May 22 2019 9:26am
holland389
France
as far as I can tell, up to now, yes, it happens all the time. I have some other advice i.e. put in neutral with park brake off, perhaps let it settle....etc...! it all seems a bit of a faff really. I only wanted to do it to let my aged relative find it easier to access the car. I have no fault warning lights but I have not checked the fault code message logs......something else I can do. I thought that I'd come onto the forum and some flash of inspiration would be forthcoming but it appears that it might just be idiosyncratic of a 2006 RRSPORT.
Post #581201 Wed May 22 2019 4:41pm
holland389
France
See my response to Father Jack. You all appear to understand that the car has foibles.....! I will do as you describe, mess around a bit, but I don't think its worth wasting time over especially when my parking brake module is making noises and won't apply.
Phil
Post #581203 Wed May 22 2019 4:43pm
Yeah, as plumber says, try and select access in the last 30 seconds of your journey.
It will drop down when the speed reduces
Post #581207 Wed May 22 2019 4:52pm
Brit Plumber
I think, as has been suggested, at stand still the sensors think there’s an obstruction so go to extended mode. The suspension geometry massively changes when you select access and all that weight is trying to push the wheels out. It does put a lot of strain on components and can cause excessive and premature ware. 2019 5.0 SC SVA (Current)
Post #581234 Thu May 23 2019 6:54am
Father Jack
Mine to be fair is placed in access every time I park it with no issues (over 50k miles) other than the occasional issue I refer to in my post above. Typical RRS lottery I suppose but see if you can find any fault codes which might help you to a resolution.
Post #581264 Thu May 23 2019 8:23pm
holland389
France
I forgot to reply
it works now as long as I select the access ride hight just before the car comes to a stop.
Thanks, apologies for delay in responding.
Phil
Post #585498 Sat Aug 17 2019 11:57pm
