![]() | Home > In Car Electronics > Black Edition Hi Fi Specs |
I think I have the wiring diagram, I was thinking of trying the Meridian speakers as they aren’t to expensive and it’s the same premium amp. I need to see if the IAM can be re flashed for meridian software as I’m sure the Gen 2.1 Level 3 IAM is the same between late Sport and Meridian equipped LR4. 2019 5.0 SC SVA (Current)
Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656 ![]() ![]() ![]() |
Interesting Brit Plumber, thanks for the reply. Do you happen to know the sizes of all the door speakers front and rear? 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
Are you sure it is 825W?
Hi Col,
I have the same system in my A/B and to be fair never noticed any issues, but then again my day's of A/C-D/C etc. at full blast have long gone, well I do occasionally when on my own. |
I have no idea of the sizes and fitting of any of the speakers. The meridian speakers (some remain the same as the HK system) have 2 speakers per position so I think the 17 speakers of the HK become 19 in the Meridian. 2019 5.0 SC SVA (Current)
Interesting really the Meridian 19 speaker system is rated at 880W the 17 speaker H/K is 1200W so would that not make the H/K system more powerful, not that I have a clue what it all means really as not audio engineer, meridian signature system has 23 speakers if I understand correctly and rated 1700W.
I think its all abit of a misconception as 17 speakers isn’t actually 17 speakers looking at the wiring diagrams. I can only find 14 in the car so i think some must be duel voice coil and they count them as a speaker |
Good point not sure where the 17 are.
The Amp is a 15 channel amp driving 17 Speakers in the HK system and 19 in the Meridian (for Disco 4 as speakers are same dims as sport).
Out of curiosity just had another look at this, not sure L/R know what they have fitted either, as found info. that say's Logic 7 is 600w and another place it say's 850w as originally mentioned, so who knows. Cheers Col |
