Home > Maintenance & Modifications > Lowering RRS options
Dougall2001
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
Hi Guys,
I’m still a boy racer really but I really like my RRS stance in the access mode. Obviously once I go above a certain speed the car raises up to normal height. My question is what options are there available to keep my RRS around that access height (or a bit lower) permanently or for when just generally on road driving?
Thanks 2014 RR Sport Autobiography - Best looking sofa on wheels I’ve ever owned
Post #579381 Mon Apr 22 2019 2:44am
garrycol
Australia
LLAMS 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #579386 Mon Apr 22 2019 6:00am
Tyrefitter
When in access mode it’s virtually on the stops so I cannot see you getting it any lower without expensive modifications,you can iirc buy the ID tool that will probably let you lower it by 5-10mm. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #579393 Mon Apr 22 2019 7:51am
Brit Plumber
If I drive mine in access mode there is no suspension travel left and it’s so bloody uncomfortable I wouldn’t want to travel any distance like it. You will also probably find issues with your suspension components and tyres very quickly. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #579394 Mon Apr 22 2019 7:53am
Yeah you want to set it between access and normal For the best of everything
Post #579397 Mon Apr 22 2019 8:05am
geoffsnook
You can lower/raise it plus or minus 50mm with an IDD not sure as said what extra wear if any it would cause Thumbs Up
Post #579403 Mon Apr 22 2019 8:56am
Brit Plumber
I dropped mine by 10mm but then when I lowered it to access it would fail and enter extended mode. I’ve now got it on a 5mm drop with no issues. 2019 5.0 SC SVA (Current)
Post #579547 Wed Apr 24 2019 2:38pm
Tyrefitter
The op might be interested in this Laughing
 Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #579549 Wed Apr 24 2019 2:43pm
Dougall2001
Love that Mate Thumbs Up Thumbs Up 2014 RR Sport Autobiography - Best looking sofa on wheels I’ve ever owned
Post #579550 Wed Apr 24 2019 2:51pm
geoffsnook
Bet Mgtow127@gmail.com would not like the depreciation on that one Rolling with laughter Rolling with laughter
Post #579556 Wed Apr 24 2019 5:30pm
