Home > Technical > Rear discs and pad replacement
Graham Ives
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
As above anything I should be wary of changing rear pads and discs on my12rrs thanks in advance guys
Regards graham Rrs sport 2012 Orkney grey
Post #579278 Fri Apr 19 2019 7:22pm
Its good to remove the hand brake shoes and lubricate the moving pivot which attaches to the cable
There is a brake bible on here which u should read
Post #579279 Fri Apr 19 2019 7:28pm
Graham Ives
Thanks Andy I see if I can source it Wink Rrs sport 2012 Orkney grey
Post #579284 Fri Apr 19 2019 8:35pm
Here you go, although he might have a later version by now.
https://disco3.co.uk/gallery/albums/userpi...1.4sml.pdf
Post #579303 Sat Apr 20 2019 2:58am
Brit Plumber
Re: Rear discs and pad replacement
Regards graham
For the price of EPB shoes, I’d do them too. My 2012 LH EPB Shoe has just delaminated making a terrible noise so I’m having to replace Shoes £28, Gen Rear discs £60 and EBC red stuff pads £70 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #579366 Sun Apr 21 2019 5:25pm
