Home > Tips & Tricks > Preventing a wet cabin filter and footwell
knwatkins
The air intake for the cabin filter is a very poor design on the RRS and the Disco 3/4. If water manages to get past the seal on the scuttle panel, it is able to flow straight into the air intake which sits slightly forward of the windscreen on the one corner. This will cause the cabin filter and footwell to become wet.
Here's a picture from one of the members on the disco forum which shows the problem....
So whilst I was refurbishing the scuttle panel today on my RRS, I decided to cut a piece of flexible plastic and fix it in place to prevent water ingress. It's simply stuck in place with some silicone sealant...
 Kev
Post #578927 Sat Apr 13 2019 8:50pm
Stevepd
Kev,
I did the same on mine but I tywrapped mine using the 2 holes seen in your picture then RTV sealant. It’s been bone dry for over 2 years now Thumbs Up
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #578949 Sun Apr 14 2019 12:16pm
knwatkins
That's good to know Steve. I did think about using the holes but I didn't want to prevent the clips from going back in. I found some opened silicone hanging around in the shed so I thought I'd make use out of it before it goes off. It seemed to stick well, but time will tell. Kev
Post #578950 Sun Apr 14 2019 12:29pm
Stevepd
Sorry I didn’t explain very well. The 2 holes in the cabin intake not where the trim pins go Thumbs Up
Post #578956 Sun Apr 14 2019 2:13pm
