Home > General > Electrical problems after sun roof leak - RRS HSE 2006
SpikeUK
I've hoovered out and dried out a lot of water from both front footwells, after both front sun roof drains perished. They are replaced.
The driver's seat and wing mirrors stopped working, and I found it was a dodgy splice with 3 red / white wires under the passenger door trim. I've fixed that with solder and shrink wrap.
Further electrical problems I'm having are:
Brake pads warning light keeps coming on, even though pads are recently replaced.
Boot warning light comes on, even though boot is firmly shut.
Alarm keeps sounding. I've got to leave vehicle unlocked to keep it quiet.
My question is, are there any more dodgy splices under the carpet that could be causing these problems? There are lots of splices
under there, wrapped up with insulating tape (shoddy, shoddy workmanship, LandRover), but I don't want to refresh all of them as in most cases the wires are too short to do it easily, and it's a lot of work.
If there's one or two that are likely candidates, I'll just do them.
Thanks.
Post #578039 Thu Mar 28 2019 12:57pm
Brit Plumber
Someone who’s experienced this will be able to confirm this, but I suspect you’re fuse box behind the glove box will be soaking. It’s also doubles up as a control module so drop the glove box and take a look. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #578055 Thu Mar 28 2019 6:01pm
Brit Plumber
http://www.rrsport.co.uk/forum/topic52887....nroof+leak 2019 5.0 SC SVA (Current)
Post #578056 Thu Mar 28 2019 6:05pm
