Home > Technical > SMOKING V8 DIESEL
Mantaraman
United Kingdom 2007 Range Rover Sport TDV8 HSE Siberian Silver
SMOKING V8 DIESEL
Can anyone shed any light on why my 2007 V8 Diesel should belch out clouds of white smoke from under the bonnet after starting? It's not from the exhaust and it doesn't smell of anything obvious. It happens mostly after the car has stood for a couple of days or more and I drive it a few hundred metres from cold and then stop. I'm guessing that one of the fluids is dripping onto the exhaust and I'm seeing it being burnt off. Anybody encountered this one?
Post #577836 Mon Mar 25 2019 5:34pm
gogsy1956
It's not by the left wheel arch by chance,, and has it been a bit chilly, like below 5 deg?. If this as the case I would suspect it's the fuel burning heater cutting in, it exhausts towards the left wheel arch area. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #577842 Mon Mar 25 2019 6:50pm
Eaters
Re: SMOKING V8 DIESEL
A common problem that isn’t a problem at all! This means your fuel burning heater is working properly. Thumbs Up
It’s designed to prewar the engine in cold conditions and so reduce stress on the engine just after starting. It also reduces harmful exhaust gasses as the engine warms up. I have a remote fitted to mine and use it frequently even in summer! Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #577853 Mon Mar 25 2019 8:09pm
