Home > Faults & Fixes > 2008 2.7 RRS P020D Fault Code
George H
Hello,
Since changing the N/S EGR valve on my RRS I an now getting a Generic Fault Code "P020D Cylinder 4 Injection Timing" The code is intermittent as the vehicle can run fine for a number of hours before triggering the code & then going into limp mode. My local LR specialist is booked up until the middle of next month & I really can not afford to take to main dealer. Any direction & help would be greatly appreciated.
Post #577802 Mon Mar 25 2019 12:04pm
Brit Plumber
Any signs of a fuel leek? Recheck all your seals and connections. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #577804 Mon Mar 25 2019 12:54pm
Brit Plumber
Oh and welcome to the forum, you come from my neck of the woods. Born in Penrith but brought up in Kendal. 2019 5.0 SC SVA (Current)
Post #577805 Mon Mar 25 2019 12:56pm
