![]() | Home > Maintenance & Modifications > 2007 3.6 tdv8 belt change |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
You probably won't find one written by someone on here as the aux belt is a "change if required" item only.
This needs to be resolved. The maintenance check sheet for UK and EU all models item 25 is change ancillary drive belt at105k miles for the 'diesel' but doesn't specify TDV6 or TDV8.
