Home > Maintenance & Modifications > 360 Surround camera option on RR SPORT -Worth it?
dcay
Hello
Currently finalizing spec for RR Sport HSE Dynamic which i see has a reversing camera as standard; However, is the 360 surround camera a worthwhile option? My offroading will be somewhat minimal and I have heard mixed reviews about the useability of the 360 camera.
Does anyone on here have the 360 camera is it worthwhile/ helpful i.e. do you actually use it often?
Also, could the surround camera be retrofitted?
Any guidance is appreciated.
Thanks
Dcay.
Post #576159 Sat Mar 02 2019 7:41am
scrumps
Hi,
Had them on the 16MY AB I just chopped back - didn’t spec them on the new 19MY.
T-junction view hard to understand what you’re looking at.
Kerb view OK for parking but if manoeuvring in tight spaces the surround view & kerb view are switched to rear view every time you select reverse gear.
Most frustrating so “not this time”
Don’t think you can retrofit due to cost of replacement items, wiring loom & software config (but I might be wrong)
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #576166 Sat Mar 02 2019 8:46am
Oldandconfused
I have an MY10 with 360 camera, not used it once in the 18 months I've owned it.
Post #576167 Sat Mar 02 2019 8:46am
PEACHY
Welcome to the forum Thumbs Up I have the surround camera system fitted - I find it useful when driving through McDonalds & other tight cornering areas Laughing - I use it every time - there is nothing worse than the sound of a brand new alloy scrapping against a Censored kerb Big Cry 16MY Estoril Blue SVR.............
Post #576169 Sat Mar 02 2019 8:51am
Got it on my MY13 not much use really, only time ever gets switched on is to see if still works.
Post #576171 Sat Mar 02 2019 8:53am
syl
Have it on one, not on the other. Don’t use it. May be useful if I towed with the advanced tow assist feature, but I don’t. RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #576174 Sat Mar 02 2019 9:13am
Lindab
Never use it. Find the pictures are a bit confusing although I suppose using them all the time would help. Had two cameras replaced under warranty. Only discovered it as I hit the camera button by accident one day. Would not spec them again
Post #576195 Sat Mar 02 2019 12:59pm
MGO
Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
had it on a volvo XC90... and i have to say i thought on that vehicle it was fantastic... especially when entering or exiting very tight twisty multistory car parks
haven't had it on a Landrover yet 2007 TDV6 RRS HSE..now gone
2012 3.0 SDV6 RRS HSE
Post #576234 Sat Mar 02 2019 9:01pm
