Home > In Car Electronics > CANBUS
rjbrocklesby
England 2012 Range Rover Sport SDV6 HSE Lux Orkney Grey
CANBUS
Hi.
Does anyone know if the RRS 2012 electrical system is CANBUS?
Looking at getting some replacement LED reverse lights and don't want system errors.
Thanks
Ron 2012 SDV6 HSE LUXURY in Orkney grey.
Post #575917 Mon Feb 25 2019 9:58pm
Brit Plumber
Yes it has quite a few. I think you need resistors fitting depending on model. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #575936 Tue Feb 26 2019 10:17am
david007
United Kingdom 2011 Range Rover Sport SDV6 SE Vesuvius Orange
Re: CANBUS
rjbrocklesby wrote:
Hi.
Thanks
Ron
I’ve fitted LED reversing lights to mine, doesn’t cause any problems. No faults or errors when checked with the IID tool.
These are the ones I fitted. 80W
https://www.aliexpress.com/item/2pcs-1156-...11702.html
Post #575941 Tue Feb 26 2019 11:31am
Brit Plumber
Sorry I missed the reverse lights, thought it said rear lights. Not sure about resistors for reverse lights, try it and see. 2019 5.0 SC SVA (Current)
Post #575972 Tue Feb 26 2019 7:23pm
