The use of an adjustable spanner or wrench is sometimes frowned upon as not being “professional” and because of the adjusting mechanism they can become worn and may not fit the fastener very well. A slipping adjustable spanner is dangerous and can also damage the fastener.
This new self adjusting spanner set from Laser Tools is different — the spanner is pushed onto the fastener, it adjusts to the correct size, then actually tightens its grip as the load is applied. The mechanism is self-ratcheting which makes for quick and easy fastener removal.
There are four spanners in the set which cover the following sizes:
