![]() | Home > Wheels & Tyres > Any scrap value for damaged Alloy 20" |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4449 ![]() ![]() ![]() |
£6, if your lucky |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
I will leave it at the garage then |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
it will sell on ebay.
If ones ceacked, the rest will follow. Sell them as a set, one with a crack and buy a new set or a set of good original 2nd hand wheels. 2019 5.0 SC SVA (Current)
Dare I say that SWMBO did a 2 and a half hour drive to an airport and back and on the way back the front o/s wheel was making a grinding noise, which had stopped by the time she got back it had stopped. The following morning I had a puncture on the rear wheel o/s wheel, and when I took it in to be repaired they found the crack in the wheel. Upon inspection of the front o/s wheel the brake pads were low and believe the grinding noise was possibly the metal edge catching which may have been caused by an impact initially, or even something like a small stone was caught in the brake.
I think you may have played it correctly. It’s not worth the constant grief. The occasional reminder is essential though and the she can say things like “you will never let it go will you!” 2019 5.0 SC SVA (Current)
my big fear if I keep on is that she will get a good grip on my throat and then she will be saying "I will never let it go" |
