Home > Maintenance & Modifications > L494 rear diff failure
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
So I have a had a look under the car today and saw what I think could be the cause of the leak. It looks like it can be replaced and has a square hole in it. It was very wet with oil. I have dried it off and no signs of any more oil coming out. Will this only leak oil when warm. Photos attached, hopefully right way round.
Post #624927 Tue Jun 21 2022 5:31pm
Johnrrs
Sorry put this on wrong thread
Post #624928 Tue Jun 21 2022 5:33pm
Tyrefitter
Did you top it up with oil.? If I was you I’d top it up,it goes in the plug where it was leaking,as you top it up,as soon as it starts to run out that means it full.put bung back in give it a really good clean & run it for a few weeks & check it again. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #624931 Tue Jun 21 2022 6:37pm
Johnrrs
So this is where you fill the diff with diff oil then??
Post #624933 Tue Jun 21 2022 7:08pm
Tyrefitter
I’m trying to work out from the pic wether that bung is the bottom one or the one half way up,,you fill it with the one half way up. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #624936 Tue Jun 21 2022 7:13pm
Johnrrs
It’s definitely the bottom one. It’s the only one I can get to without lifting the car
Post #624942 Tue Jun 21 2022 8:25pm
Johnrrs
Would this only leak when the engine is warm or all the time?
Post #624943 Tue Jun 21 2022 8:27pm
that is definitely the drain plug, the only thing you can do is to tighten it now until you can it to a workshop/change the oil yourself.
it will mostly leak when the oil in the diff is warm, or if there are big changes in ambient temperatures. --
Post #624947 Wed Jun 22 2022 6:57am
