Home > General (L494) > ACC / Disabling "follow mode"?
Page 1 of 3 123>
harisson
Switzerland
hello all
I have a MY16 SDV6 ATB with the famous adaptive cruise control (ACC).
are the owners of a MY16 able to disable the "follow mode" so that the ACC is only a "CC" (only cruise control funtion) with a "stubborn" holding of the cruising speed?
disabling by holding the "distance reduce" button long (3 seconds)
my dealer told me, that it's possible from MY17 and I am wondering if somebody of you is able to disable it on a MY16. if yes, do you know which SW do you have on your RRS?
(I can't really believe that's not possible on MY16 because I suppose it's just a SW-update)
why I am asking: the ACC functionality I don't like. If I drive (on German Autobahn) 160km/h on the left side and going into a left curve, on the right side is a truck - the RRS will slow down strongly.. I find it quite dangerous on such velocities..
Thanks!
Harisson Range Rover Sport HST D350
Post #573138 Tue Jan 15 2019 1:37pm
I didn't think the follow mode could be disabled. Mine's a MY15, but will try it tomorrow on the highway and report back. --
Post #573164 Tue Jan 15 2019 8:56pm
harisson
Switzerland
Thank you naks Smile
Looking forward to hear your result
When you push and hold the reduce button for the distance, a message should appear in the IC that the follow mode is deactivated, or something like that... Range Rover Sport HST D350
Post #573192 Wed Jan 16 2019 8:01am
No problem.
I'm assuming I can re-enable it the same way? --
Post #573194 Wed Jan 16 2019 8:20am
harisson
Switzerland
Yes should be so. If you push the increase button, the acc should be reactivated.
If you google a bit, you will find that it's possible on the evoque and also ond Jags Range Rover Sport HST D350
Post #573196 Wed Jan 16 2019 8:32am
Ok, I drove 50km to the physio and 50km back home, most of it on the highway, and I can report that this method does NOT disable the ACC.
I tried with the ACC on and off, and it made no difference. --
Post #573242 Wed Jan 16 2019 7:50pm
harisson
Switzerland
Thanks naks!
Maybe someone with a MY16 and someone with a MY17 will try Range Rover Sport HST D350
Post #573257 Wed Jan 16 2019 10:46pm
harisson
Switzerland
I am pushing up this topic..
Can anyone with a MY16 (or MY15) try to disable the follow mode of the ACC?
With the MY17 it works... Range Rover Sport HST D350
Post #583842 Thu Jul 11 2019 8:06pm
I do know that you can disable ACC and just have CC on the original RRS using an IID Tool or similar to change the Car Configuration File (CCF). Assuming LR still use CCFs, it might be worth seeing if your dealer, or an independent LR specialist, can alter the CCF for you. 2012 SDV6 - it's missing a couple of cylinders
Post #583856 Fri Jul 12 2019 8:36am
harisson
Switzerland
Thanks for the answer
Then, you only have the cruise controp without acc permanentely?
My dealer can't help. He asked also for a SW update, but seems there is nothing for MY16
I thought a SW update of the ACC would enable the possibility to disable it.
It's the only thing which is annoying on my RRS Range Rover Sport HST D350
Post #583877 Fri Jul 12 2019 1:51pm
Tim in Scotland
Even back in 2005 this was a problem with JLR’s ACC, I had it on my 2007 TDv8 and in winter the sensor in the front bumper would get slush/snow on it on the motorway and once the message “sensor blocked” flashed on the dash there was no cruise control at all, not even conventional non-adaptive. It seems that the JLR ostrich still has its head firmly stuck in the sand 12 years later....... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #583878 Fri Jul 12 2019 1:57pm
harisson
Switzerland
That issue with snow-covered acc radar I didn't have
Just wondering if other owners can disable the follow mode... Range Rover Sport HST D350
Post #583898 Fri Jul 12 2019 9:48pm
Spleen
I've got ACC but unfortunately I'm nowhere near my car to see if I can disable follow mode. it's not CC but ISL might be an alternative? Ferrari F430 Spider F1
MY17 RRS AB V6
2CV6 Special
Post #583910 Sat Jul 13 2019 9:29am
Tyrefitter
Doesn’t it now work off the centre roof consul.?if so put a sticker on the outside of the screen & see if that works. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #583930 Sat Jul 13 2019 1:21pm
harisson
Switzerland
Tyrefitter.. sorry, which screen you mean? As fahr as I know the radar is under the front plate.. Range Rover Sport HST D350
Post #583957 Sat Jul 13 2019 10:15pm
Page 1 of 3 123>
