![]() | Home > General (L494) > Rear wiper blade! |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 ![]() ![]() ![]() |
After extensive internet “research” I figured out that the correct rear wiper for the l494 (2016 model) was the Bosch h384.
BigBen Member Since: 15 Dec 2015 Location: Hertfordshire Posts: 88 ![]() ![]() |
You can obtain the standard OE rear blade from Dan at Duckworths (site sponsor). Make not known but be warned the standard O E rear blade is a poor performer and does not clean screen very well. I have not found any alternative - Bosch do the front ones but not apparently the rear. |
Bosch a381h looks like it should fit. Ordered one, watch this space! Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
gtr_skyline Member Since: 28 Apr 2018 Location: St Albans Posts: 245 ![]() ![]() |
How did you get on with the a381h ? Thanks Prashan MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian |
Yes, straight swap/ correct fitting |
Many thanks... off to eBay now MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian |
dobbo9 Member Since: 04 Dec 2011 Location: West Yorkshire Posts: 108 ![]() |
I ordered this a381h for my 2015. Not correct having to return it to ECP. |
Mine is 2015 65 reg (so 2016 model) must be when it changed. Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Never found an aftermarket blade that fitted mine, always had to go to the Dealer spares dep't. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Bought a full set from the local LR dealer yesterday. Like for like direct replacement. Simples. |
X31RDS Member Since: 18 Jan 2019 Location: Staffordshire Posts: 14 ![]() ![]() ![]() |
How much did they cost. I need a set too and RR is going to dealer tomorrow for some warranty work. |
andymc Member Since: 04 Jan 2017 Location: london Posts: 127 ![]() ![]() |
Might be a ECP issue. I checked the Bosch model numbers they recommend for my car and then are different to those recommended by the Halfords tool. Never had a wrong wiper from Halfords before so tend to use them as a benchmark. SVR with a few bits from Urban and Glohh |
£71 inc vat for a full set. Took 1 minute to swap |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 542 ![]() |
If yours is the floppy type blade wiper then the correct one is definately the Bosch A381H.... straight fit on my 16MY 494...
