![]() | Home > In Car Electronics > I have the Logic 3 system, sounds awful!! |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 316 ![]() ![]() ![]() |
Sounds like the sub isn't working. Mine comes and goes, it never sounds amazing but it's a lot better when it's working. Check for fault codes on the audio system |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
The V6 subs are usless.
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 ![]() ![]() ![]() |
Ill run it in to my local car audio centre they worked wonders on my current Defender! Guess I’ll have a better sub nailed in there! LR should be ashamed of themselves it’s the little finishing touches like the quality of audio sound system that makes all the difference IMHO for what it’s worth? Great product let down by silly little things - ridiculous |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 ![]() ![]() ![]() |
I wouldn't agree the subs are useless but they are not hugely loud and will not make the earth move if that is your thing. More the issue is JLR skimped on the soundproofing in the tailgate and trim so they rattle like a pig as a result. But that is relatively easy and cheap to fix for around 30 quid or so and I put a how to in the tips and tricks. |
I've been advised by my local car audio centre to change the sub in the tailgate. Has anybody done this to improve the base? What one did they instal? Cheers Laurence. |
See above and my post on the topic in tips and tricks section. No need to change out driver just sort the lack of dampening which causes the problem. Cheap and effective.
