Home > My Range Rover Sport > A moment of clarity |
Uk Spooks Member Since: 30 Nov 2018 Location: Worcestershire Posts: 11 |
Sun Dec 23 2018 1:14am |
thomas brown Member Since: 29 Mar 2016 Location: Norwich Posts: 559 |
Looks a stunning sport Love them when they are just left untouched, very classy.
Sun Dec 23 2018 8:54pm |
Thank you,, |
Wed Dec 26 2018 8:30pm |
Thank you and i agree with your comment,,, Thomas brown |
Wed Dec 26 2018 8:32pm |
Hope everyone is having a great Christmas. Just an update. Since owning the RRs which is about 6 weeks now,i have travelled about 2300 miles trouble free,apart from a few niggling things that needed doing. So first thing i noticed was a drip coming from the passenger side a pillar at the top inside the vehicle,making the passenger side slightly damp which turned out to be the sunroof drain tube being blocked. Also the driver side foot-well was really soaked underneath carpet. Which was partially caused by the sunroof drainage tube being blocked also. After cleaning both tubes are now clear and draining properly.Driver side however has been doing my fruit in I found out that the A pillar on the outside could be of fault,so i ordered the updated repair kit and followed the instructions and seems to be working and no more leaks. Though i have not put all the floor panels back properly as i am still checking for water. ,I will put everything back at the weekend. The key fob would not lock the doors but that was due to water ingress on the passenger side which is now fixed. The three green wires in the loom which i cut and soldered and all is well. I also found out that my engine is the non dpf version which i am happy about,but only 95% certain. I will try and find out for sure before topping up oil. I can not see any dpf on the exhaust. Anyways i have travelled up to Yorkshire from Worcestershire and at this point just getting g some stuff ready to travel up to Loch Ness Inverness which we will be leaving about 4/5am then onto Fort William, then loch lomond. So will update my journey when i can. Maybe some pics.Anyways just thought you may want to know |
Wed Dec 26 2018 9:07pm |
Top job UK spooks keep the updates coming.
Wed Dec 26 2018 9:17pm |
Yeah i am enjoying Centurion (name of car,but not set in stone yet ) I also forgot to mention that i couldn't seem to know if the air con was working correctly so had a service done. Now here is the thing, the system was supposed to be holding 650g of gas/oil but when checked it only had 10g Good god i thought, that's a bad sign,but anyways service was done pressure holding and no leaks are detected,and the system is now brutally cold so fingers crossed that over the next few days i it dosn't leak and keeps working as it should,but for the amount that was in the system makes me think that there could be a small leak,so will find out i guess |
Wed Dec 26 2018 9:52pm |
XIII Member Since: 11 Apr 2016 Location: Radlett Posts: 37 |
Nice car |
Wed Dec 26 2018 10:32pm |
DPFs were only fitted to Facelift cars - the originals in the UK didn’t have them. Roll out date for DPF RRS was 2010 with the face lift.
Thu Dec 27 2018 5:07am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849 |
A book I have States the DPF wasn’t fitted to the 2009 59 plate face lift cars but was for 2010. 2019 5.0 SC SVA (Current)
Thu Dec 27 2018 8:20am |
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 |
Nice Car
Thu Dec 27 2018 5:12pm |
Sham91 Member Since: 24 May 2018 Location: Bradford Posts: 178 |
hold on...I have a 59 plate facelift tdv6...so I dont have DPF??? happy days lol RRS TDV6 2010 |
Fri Dec 28 2018 12:34pm |
Thanks for the info on the DPF and the roads back from Loch Ness. I have driven the route before a few times and love the drive. |
Mon Dec 31 2018 7:19pm |
This picture is just up the road from the Hotel called the Clansman at Loch Ness, been here before and can recommend staying here.
Mon Dec 31 2018 7:22pm |
