Home > General > Buying RRS 2013 Black Edition |
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 |
On the other hand, if you’re still looking for a black one . . . .
Sat Dec 22 2018 4:50pm |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677 |
Buster if it’s the blue round the wheels that are putting you off,,they are just rim protectors & if they are the ones that fit by going in between the rim & tyre they are waste of time as they trap water & cause leaks but they are easy to remove or they could be the ones that stick on,either way a total wast of time if you hit the kerb hard enough it will still garage rim. Andy.
Sun Dec 23 2018 12:40pm |
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 |
Andy, no not the blue rims although they are awful! It’s just not the spec I wanted Cheers Laurence. |
Sun Dec 23 2018 2:35pm |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 472 |
Its a long way from you but,,
Sun Dec 23 2018 3:51pm |
^^Thanks but not keen on the wood trim... ^^^ Cheers Laurence. |
Sun Dec 23 2018 10:15pm |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 |
Doesn’t look like it’s got the heated steering wheel either 2016 Black SDV8 Autobiography
Sun Dec 23 2018 10:30pm |
Or the white stitching Cheers Laurence. |
Sun Dec 23 2018 10:44pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849 |
Is the white stitching called cirrus? 2019 5.0 SC SVA (Current)
Sun Dec 23 2018 11:39pm |
Thought it was just ‘contrast white stitching’? Cheers Laurence. |
Mon Dec 24 2018 2:45pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5024 |
The white stiching on my A/B seats is referred to as "Cirrus Contrast Stiching" in the build spec.
Mon Dec 24 2018 8:02pm |
That’s it, cirrus contrast, mines more of a tan stitch than white. 2019 5.0 SC SVA (Current)
Mon Dec 24 2018 8:26pm |
^^Really? Do they mark easy? I guess they can be cleaned?^^ Cheers Laurence. |
Mon Dec 24 2018 11:32pm |
The only place my stitching shows discolouration is the front armrest ends, they are a little darker than the rest of the stitch. 2019 5.0 SC SVA (Current)
Mon Dec 24 2018 11:36pm |
Wouldn't say mine was discoloured but cleans up ok if it gets a bit grubby, not sure I would want it on a steering wheel though, but I do have a piano black wood and leather sports wheel fitted any way.
Tue Dec 25 2018 4:06am |
