![]() | Home > General > Transmission fault |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
I also have a 2005 TDV6. I should also point out that I am no expert nor have I the LR experience of the majority of members here. I had the same fault come up a while ago. I knew I was losing oil and was on the way to my mechanic when it came up. From what I can gather, what you have described can occur for a number of reasons. I think I even read once that it can happen if there is a simple electrical short / fuse / bulb blown. I know this doesn't answer your question - just sharing my experience. I'm sure you'll get some helpful responses. Good luck. Barrie.
