Home > Faults & Fixes > Removing Tow Bar - Key Snapped - Plymouth
Jaws
Evening All!
Looking to get a tow bar removed from a RR Sport I just purchased. It's a lovely car but I have no intention of towing anything and I could do without it, only problem is, the key seems to be snapped in the lock!
I did purchase a spare key but obviously this is somewhat redundant.
Would any members around the Plymouth / Devon area be able to offer a helping hand to remove it? Happy to throw you a couple quid! I just don't have the time, tools or patience!
Unless there's any other better ideas?
Thanks!
Post #570213 Fri Nov 30 2018 6:14pm
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
If you are not going to use it in the future why not just drill the lock barrel out?
Jim
Post #570218 Fri Nov 30 2018 6:42pm
Jaws
That's exactly what I'd like to do but I have literally no tools. Happy to throw someone a couple beer tokens to do it for me!
Post #570219 Fri Nov 30 2018 6:52pm
hoppy_70
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Rimini Red
If the keys snapped in then hammer a screwdriver in next to it then turn. Otherwise tap the pin out (hole on top of lock) then the lock will just pull off revealing the shaft. Shaft will turn with grips. Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Range Rover sport HSE Dynamic P400e Silver
Range Rover Sport 3.0 SDV6 HSE Dynamic 2016 MY
Range Rover sport 3.6tdv8HSE 2007 Gone
Range Rover sport 2.7tdv6SE 2005 Gone
Range Rover sport 2.7tdv6SE 2007 honey
Range rover Vogue 2005 4.4 - GONE and missed
BMW 535d M sport 2006 - GONE not as missed
BMW X5 4.4 2004 sport - GONE
Post #570240 Fri Nov 30 2018 9:41pm
Jaws
Perfect, thanks!
Post #570242 Fri Nov 30 2018 9:54pm
If you do break the lock off in any way take care not to break the piece of Red Plastic behind the Green Knob as this is not available separate, you could then get a new lock kit for around £20.00 and have a perfectly good tow bar to either keep or sell on for good money.
Post #570243 Fri Nov 30 2018 9:58pm
