Home > In Car Electronics > Sound system identification
PC76
Afternoon all.
i am after upgrading my stereo on my10 face lift 3.0 TDV6.
i have two options, keep original and add Bluetooth capability to the Aux port (from Incartec) or swap the unit for a double din and loose 4*4.
firstly i need to confirm which stereo system i have installed as this will effect choice & ease of installation. Is there an easy way to confirm this without pulling things apart?
Secondly, if i swap the unit out what are the pro's and con's. i believe i will loose the 4*4 screen but what other features would i loose...
Thanks
Post #569918 Tue Nov 27 2018 4:02pm
well its an HSE, so assuming its amp under the seat and difficult
Post #569944 Tue Nov 27 2018 7:40pm
I thought there was only a choice of two, Harmon Kardon, used to be called (Hi Ice Pack) I think and the Harmon Kardon Logic 7, if it's logic 7, I think it has a small badge on the speaker grill saying Logic as well as extra speakers. The build spec. from topix should tell you although sometimes that is not always correct.
Post #569951 Tue Nov 27 2018 8:46pm
