Home > General > Fuel Burning Heater |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
That's normal. should really only happen once as it doesn't get used during he warmer months. on the next cold start you should see considerably less smoke.
Thu Nov 22 2018 11:59am |
It is common if it is the first time in the year that it has cut in, often there is unburned fuel solidified in the burner and that has to clear from the system. I had it happen on my 2005 TDv6 several times in the autumn after the first time the temperatures dropped below 5c and the FBH cut in 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Nov 22 2018 1:11pm |
Sham91 Member Since: 24 May 2018 Location: Bradford Posts: 178 |
yeah the car was sat in garage and not driven from Jan 2018 up until August 2018 so sounds like this is normal
Thu Nov 22 2018 2:11pm |
Hugh Haddow Member Since: 03 Jul 2009 Location: Prestwick Posts: 202 |
Did it smell like burning or very hot rubber by any chance? |
Thu Nov 22 2018 4:27pm |
Hugh Haddow I cant really be sure now tbh, i'd sway towards burning....not sure what hot rubber smells like but could also smell some through the inside heating vents when I turned it off and back on for a few seconds and then no smell at all |
Thu Nov 22 2018 4:40pm |
Thanks Sham. |
Thu Nov 22 2018 5:34pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
I had the key remote system added to my FBH a few years ago and use it quite a lot even through the summer (although not so much this summer!). My logic says that if I can warm the car up a bit then it puts less strain on the engine at start up. And if it just a short journey I've planned then this makes even more sense. Robin
Fri Nov 23 2018 8:44am |
