Home > Faults & Fixes > 2007 RRS | Sunroof actuator?
HughN
Wales
Before I start pulling the headlining apart, could someone please enlighten me as to where I can find the sunroof actuator?
I got something jammed in it and it is half open. The fuse is OK and it won't reset via the 'tilt' switch (IID shows actuator fault).
Thanks!
Post #569168 Sun Nov 18 2018 7:19am
Not sure on a pre facelift, but on facelift if you pop out the overhead interior light console it's all under there, so would suspect it's the same.
Post #569174 Sun Nov 18 2018 9:22am
HughN
Wales
Thanks - found it behind the bracket. One side of the glass is well-and-truly stuck. Tarp and gaffer tape it is (for now)
200 miles on the M4 at 70 (+) with the sunroof open last night was A BIT NOISY Shocked
Post #569178 Sun Nov 18 2018 11:36am
