Home > Faults & Fixes > MY18 - Auto Steering Column Adjust Stopped Working
jd2uk
Hi,
Normally when I turn off the vehicle the drivers seat will move back and the steering wheel will move back towards the instrument cluster and up to make it easier to get out of the vehicle. Over the past couple of days I've noticed that it's stopped doing this. The 'Auto column adjust' is still enabled using the switch in the steering column and the steering wheel and seat can still be adjusted manually so all of the electronics are still working.
Anyone had this problem before I get it booked it at the dealers?
Thanks,
James
Post #569068 Fri Nov 16 2018 9:57am
