![]() | Home > Maintenance & Modifications > Suspension light after putting 250kg in the boot |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5032 ![]() ![]() ![]() |
No. Read codes.
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 ![]() |
Yellow light
Yes you do need a code to know what is bringing on the light |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
That's only like having a couple of opera-singers on the back seats. |
Can I still drive the car? 2006 RRS Supercharged 4.2 HST muthuaflecka! |
Yeah.
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 ![]() ![]() ![]() |
Agree you need to get codes read but 250 kg should not have affected a healthy setup. I carry a drumkit and other gear regularly which is around the same total weight with no dramas at all. Thank god for self levelling air suspension and access height setting... |
Agree 250 kg's is less the 4 adults so there must be something wrong/broken in the setup |
