Home > Technical > RR sport 2009 rear suspension clu |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849 |
Cant answer your question mate but just be aware that if you go under the car, the suspension can be active for hours after ignition off and can re-level itself with out warning and any time. 2019 5.0 SC SVA (Current)
Sat Oct 27 2018 8:24pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
I would start by looking at the arb bushes and links 2008 G4 RRSport TDV8 current
Sat Oct 27 2018 10:52pm |
Demaske1 Member Since: 17 Oct 2018 Location: Cheshire Posts: 26 |
so the car has now been to a suspension specialists. I asked them to check anti roll bar bushes and they said it wasn't those it was the bottom arms and they don't replace the arms just the bushes with better ones. That job has been done and even though quieter there is the odd clunk still. They now believe there is a stop on the sway bar and is occasionally hitting the side of the chassis and this is caused by the anti roll bar bushes letting the bar move from side to side occasionally causing the knock.
Thu Nov 29 2018 2:20pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
The bar does have lateral movement in it as that's how it works. Shimming the ARB bushes is a known solution. 2012 SDV6 - it's missing a couple of cylinders
Thu Nov 29 2018 5:17pm |
