![]() | Home > Technical > Key Fobs Intermittent Unlock Fault Both Fobs |
Hi and welcome there is a chap on here that does a refurb on the fobs which i believe will get rid of most issues also there is a problem that may be yours which is a 3 wire splice in the loom you can search for both of them on here and have a look to see which one suits you best |
Just The Ticket Member Since: 09 Sep 2018 Location: Cheshire Posts: 2 ![]() ![]() ![]() |
Many thanks for your reply, I have looked at some posts in regards to the loom splice however I thought that fix was for when the CL stop working all together, mine still works fine locking and tail its just unlock is intermittent so not sure that would cure it.
Just search on here for key fob service I think it’s RRUK that does it |
