![]() | Home > Technical > is this all battery related? hdc gearbox park brake |
What year/model have you got,my14 came up with hdc gearbox fault when it was cold last winter & wouldn’t start & I turned ignition off fo a few minutes then it started & message disappeared.Ive read on here that it could be because the battery isn’t fully charged.
A bad battery can cause most of those so try plugging a charger in and leave overnight and see what it does in the morning if you can |
W18ODY Member Since: 31 Aug 2014 Location: north east Posts: 87 ![]() ![]() |
sorry i shouldve said! its a 2005 tdv6 2.7
15 and above on the battery to start is normal should only drop down after a good run but if you have lots of other things on like heated seats and Aircon it will put more strain on battery and yes the tail hate release has been known to cause battery drain as well as brake light bulbs throwing up loads of fault codes but as you have a poor starter you more than likely have a duff battery they are also supposed to be an agm style battery |
voltage was 14.4 running i havent checked it on cold start thats just what i read on here.
The more amps the better and as long as it’s an AFM battery it should not matter what make it is also 12 volts is a bit low with these cars when you start it up it should be around 15-15.4 and slowly drop but depends on what your drive is like ie short or long and why you use lights Aircon heated seats etc as I recall my Disco3 never dropped below showing 13.5 but my petrol sport seems quite happy at about 13.1 and if I only use my car to pick up wife which is about 4 miles each way the battery don’t like it but if I take it to work and that’s 10 miles each way it’s fine |
Also if it looks original then just change it for a new one |
its not 12v after startup the battery is maintaining just over 12v while switched off, basically if it maintains 12.4 volts say over the next few hours then i struggle to start it, is it still a battery problem or could it be something else?
So how long a drive do you do each time |
that was a short journey but enough to get the battery well above 12v
New battery i would say |
its looking that way!
Would have thought the alternator would have been chucking out over 15 volts if that battery was that low |
it possibly was at first this was checked at 14.8v after about 10 mins running? |
