Home > General (L494) > aircon L494 recharge |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Condenser is the most common area, big exposed rad at the front of the car...
Sat Aug 18 2018 1:11pm |
SilverAuto Member Since: 28 Aug 2015 Location: Midlands Posts: 20 |
Thanks Mikey, it goes into an independent for a leak test diagnostic on Tuesday before it goes to the dealer fingers crossed its something covered under warranty!
Sat Aug 18 2018 2:31pm |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 |
Had mine done twice in a month but both times, reported as no leaks found, and it's going off again |
Sun Aug 19 2018 8:35pm |
sally Member Since: 01 Sep 2014 Location: out and about Posts: 376 |
Modern day A/C machines are rubbish at detecting leaks imo. They test for leaks whilst the system is in a vacuumed state which unless there is a big hole they will pass the vacuum test every time, making you believe the system is fit for charging. The only way we test properly is to fill the system with compressed air to around 8 bar (which is rest pressure on a hot day), then soak the various components (mainly the condenser as its the most popular spot for leaks) with soapy water then the locate the leak from there.
Mon Aug 20 2018 1:23pm |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
Where are you based Sally? Merc C220 estate Sport AMG
Mon Aug 20 2018 3:33pm |
Seems like mine has stopped working again. Another £150 for a months working air con. Supposed to have die in the system but apparently no leaks |
Mon Aug 20 2018 5:22pm |
Ipswich but we can't do 1234yf yet . Hopefully will be a 2019 addition to our business 2012 Evoque 2014 Sport Autobiography 2015 SVR for the fun stuff 2016 Evoque SI4 Dynamic Lux for the daily drive 2016 Defender 90 2018 SVR |
Tue Aug 21 2018 10:11am |
Tue Aug 21 2018 11:40am |
