Home > Faults & Fixes > Will not start RRS 2.7 56 plate
RRS Iwan
Wales 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Good evenig all
My mate has just been on the blower and his RRS 2.7 56 plate was cutting out until it would not start at alland had to get a tow home. We share a icarsoft v2 and its been a good little machine. But the only error coming up now is EGR C and will not clear.
Any clues?
Thanks
Iwan
PS he thinks there is blanking plates on the EGRs
Post #563275 Wed Aug 15 2018 5:49pm
HEFF
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
did it not give you any other code... (example....P044E )
Post #563287 Wed Aug 15 2018 6:41pm
RRS Iwan
Will ask but the heavens have opened here in North Wales so i think my mate was glad to get home tonight.
Thanks
Post #563288 Wed Aug 15 2018 6:58pm
RRS Iwan
Fuel sender location and access
Good evening All.
Just back from my mates and it looks like the fuel sender unit is either gone or there is no supply getting to it. All fuses and relays are ok. The biggest clue was when we listened to my RRS you can hear the pump but on his nothing.
Next step is to get too the sender unit to check supply and connections. Can it be accessed from the car or does the tank need to be removed?
Your help would be appriciated
Thanks
Post #563353 Thu Aug 16 2018 7:08pm
geoffsnook
Tank out i think Thumbs Up
Post #563354 Thu Aug 16 2018 7:22pm
Disco_Mikey
Tank out
Post #563366 Thu Aug 16 2018 8:26pm
RRS Iwan
Good evening All.
Yes it was the fuel pump, after stripping the tank and getting to the pump unit and throwing a direct 12V feed we confirmed the worse. So a week later and 400 of our fine British pounds down the RRS is runing just to find out the central drive shaft baring is gone. More play than a set of nuts on a prize bull.....
Rolling with laughter
Post #563761 Wed Aug 22 2018 7:28pm
