Home > Faults & Fixes > RRS will not start
JoKa
Finland
RRS will not start
My RRS TDV6 2007 is not starting, even though I changed into a new battery today and thought this would solve the problem. It gives me the ”HDC Fault System Not Available”. The footbreak went stiff as well, sort of locking it down. Any suggestions on how to tackle this?
Post #562746 Mon Aug 06 2018 8:22pm
Brit Plumber
When you say the foot brake went stiff, did you pump the brake before it went stiff? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #562748 Mon Aug 06 2018 9:17pm
JoKa
Finland
I probably did, pushing the break pedal simultaniously when turning the key to start.
Post #562750 Mon Aug 06 2018 9:30pm
