![]() | Home > Wheels & Tyres > 22 inch tyres |
For a start they are the wrong load rating for the L494,the Toyos are only 106 when they should be 108 or above.The whining could be the tyres feathering on the inner edge,does it sound like a wheel bearing gone then if so that’s your problem,,stick a set of Pirelli or contis on but the right size,275/40r22’s.Also get your alignment checked if the are feathering.
brucei Member Since: 01 Jul 2018 Location: herts Posts: 7 ![]() ![]() |
Thanks for that Andy ill look to replace with the correct sizes.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5063 ![]() ![]() ![]() |
If they are the incorrect rated tyre for the vehicle and not rated high enough, as it's a L/R approved used vehicle it should never have been sold with those fitted, I think I would be chasing the dealer to replace them as well, not to sure about your insurance if the tyres are not correct rating for the vehicle either.
