Home > In Car Electronics > Power for headrest Screen module under seats ?
mrluke
Fitting some rosen headrests which is fine ( 2012 RRS Autobio) , unsure where to take power from for the control module .
Im thinking of using a fuse tap on the rear cig lighter fuse and running a cable from the glove box under the sill trim and then to under the passenger seat .
Any easier way ?
Thanks
Luke
Post #561174 Wed Jul 11 2018 8:38am
Certainly under the passenger seat on the early models, there is an ignition supply on the connector at the front of the seat.
or if you want a supply only when infotainment is powered up, the nav connector has a supply.
Kinda needs the seat taking out to do thought.
They are heavy and difficult to manoeuvre
Post #561183 Wed Jul 11 2018 11:06am
mrluke
Is the satnav unit under the drivers seat ? i did noticed a module with some Fiber leads going into it.
Post #561184 Wed Jul 11 2018 11:19am
No the Satnav unit is a integral part of the CD player in the center console, I think you will find the unit under the drivers seat is the TV tuner.
Post #561187 Wed Jul 11 2018 11:43am
mrluke
yep you are correct just found one on ebay
https://www.ebay.co.uk/itm/RANGE-ROVER-SPO...SwuyNbA-kx
Ok so now the question is , is the TV tuner ignition based so i can tap off the power cable Wink
I wonder if its this fuse it uses
Fuse - 68
Rating - 10
Colour - Red
Touch screen display, multi-media module, radio ,telephone
Post #561188 Wed Jul 11 2018 11:46am
Should be a Grey 20pin connector on tv tuner, try pin No.1 red wire it is the power to tuner, controlled I think from fuse No.68 wouldn't know if it is ignition live or not though.
Post #561191 Wed Jul 11 2018 12:02pm
mrluke
Thanks for the help , Will try a multimeter on the pin Very Happy if it is ignition live may have to up the fuse for the rosen screens .
Post #561192 Wed Jul 11 2018 12:05pm
mrluke
In the end the better option was a fuse tap from passenger fuse box, pulled up sill trim and ran cable under , then a little bit under the carpet and then under the passenger seat .
Does any one know what the large empty metal bracket is under the passener seat ? i assume its meant to house something..
Post #561419 Sun Jul 15 2018 6:19pm
Brit Plumber
Can you post a photo? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #561429 Sun Jul 15 2018 8:24pm
On mine it's where the surround camera control module is fitted, but assume other options can also be fitted to it as it's quite large with various mounting holes in it.
Post #561432 Sun Jul 15 2018 9:11pm
mrluke
Thanks Col ,
Finally got around to mounting the Rosen control module on there . I ended up using a couple of strips of gorilla Tape to stick it to the bracket under the seat ( saves removing the seat and screwing it into the bracket)
Looks all good in the end Wink
Post #563170 Tue Aug 14 2018 7:54am
