Home > In Car Electronics > No power to harmon kardon amp
Shaunbop
Ive just fit a aftermarket head unit using incartech's wiring loom that retains to satnav screen.
The headunit is up and working as it should but the screen is staying on the landrover screen. Ive spoke to incartech they told me I might not have power to the hk amp. ive checked and that's the problem, does the hk amp run off a separate fuse at all? if so whats the location?
Post #560943 Sun Jul 08 2018 10:46am
Have a look at Fuse No.42 30amp passengers footwell fuse box.
Post #560944 Sun Jul 08 2018 10:56am
Shaunbop
Thank you ill go look now
Post #560945 Sun Jul 08 2018 10:57am
Shaunbop
That fuse is ok
Post #560953 Sun Jul 08 2018 2:09pm
What pin on the amp have u measured to conclude the amp don't have power?
Post #560964 Sun Jul 08 2018 6:01pm
Shaunbop
I've checked all the wires in the grey plug with the multimeter
Post #561109 Tue Jul 10 2018 12:21pm
Scrumpy
Don't know if it helps but when I fitted my kit from IncarTech, I was told that I will lose the HK amp and can either make do with the new head unit's build in amp or buy a separate amp to power the subwoofer in the rear tailgate which is what I did and everything worked fine (other than lose the front centre speaker but not noticeable).
Maybe give IncarTech another call just to clarify this? 2016 RRS SVR Estoril Blue
Post #561112 Tue Jul 10 2018 1:24pm
Shaunbop
I've spoke to them mate everything works just not the centre screen. Incartech told me I've probably lost power to the hk amp
Post #561119 Tue Jul 10 2018 1:54pm
there is an optical fibre network between the headunit, screen and amp. (orange)
All 3 components need power for the network to work, unless you have unplugged the optical connection from the amp, released the orange fibre and pushed them together, that could be an issue
Have you got the back part of the old head unit still connected ?
Post #561129 Tue Jul 10 2018 5:24pm
Shaunbop
Yes I have the old bit of the head unit in place still. The optics cable is connected. It just seems I have no power to the hk amp via the grey plug.
Post #561171 Wed Jul 11 2018 7:27am
Shaunbop
Post #561212 Wed Jul 11 2018 4:51pm
I agree with Col.
The thick red wire, should have direct power from fuse 42
Post #561213 Wed Jul 11 2018 6:10pm
Shaunbop
I'll double check tomorrow.
Post #561226 Wed Jul 11 2018 8:49pm
