Home > General > 2005 rrs aircon ? |
Yes it should the light needs to be out to work |
Thu Jul 05 2018 9:10am |
ashleighash Member Since: 13 Apr 2018 Location: fulham Posts: 25 |
Hi thx what the orange light on econ needs to be off to work ? |
Thu Jul 05 2018 9:53am |
yes is arse about face with these cars |
Thu Jul 05 2018 9:58am |
Yes, and it is best not to press it in and run on auto climate control 100% of the time, it makes no difference to fuel consumption on an RRS and you just adjust the temperature settings for comfort - it will blow cold and hot air that has also been dehumidified so in winter it helps to keep the interior dry. It is also better for the electronics that they don’t get condensation on them where they are in the boot. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Jul 05 2018 10:00am |
Okie dokie I’m gonna give it a try many thx for your advice |
Thu Jul 05 2018 10:03am |
Don’t forget to test the crotch chiller under the steering column 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Jul 05 2018 10:18am |
Had mine on and open today does what it was intended to do lol |
Thu Jul 05 2018 5:15pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
These 'econ' switches are a joke. Vauxhall's had them a few years ago. If anyone knows about AC systems they will tell you that they should be ruining constantly- hot or cold otherwise the compressor seals will soon wear out. |
Fri Jul 06 2018 8:23pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4950 |
Just a conveient way to turn the AC off if the compressor starts making a noise or vibrating |
Fri Jul 06 2018 8:47pm |
hi i took rr to garage to regas as tried everything they said it was full im so lost |
Wed Aug 15 2018 8:53pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
Have you read the handbook to learn how to operate your climate control system? 07MY RRS TDV6
Thu Aug 16 2018 3:06am |
Unfortunately car didn’t come with one |
Thu Aug 16 2018 3:37am |
Get one off Topix or at least view the areas you need. There are plenty on Ebay. 07MY RRS TDV6
Thu Aug 16 2018 7:26am |
ok thankyou |
Thu Aug 16 2018 9:05am |
