Home > Technical > I’m sure this has been asked 100s of times, 'reduced power
Chrisp75
Apologies.
News to RRS and in the last three months of ownership I’ve never had a car with so many warning lights, but I guess that’s the way it goes.
So newest one is Reduced Power. It’s occuring occasionally and let it sit for a bit and it all clears.
Plugged the snap on Solus Ultra on and get the following back. I think there must be a root cause and all to do with this as I’ve previosuly cleared them all!
P00BC. Mass or volume air flow A circuit range/performance - air flow too low
P00BD. Mass or volume air flow A circuit Range/performance- air flow too high
P1247. Turbo boost pressure low
P0235. Turbocharger boost sensor A circuit
P22D2. Turbocharger turbine inlet valve stuck upon
P22CF. Turbocharger turbine inlet valve control circuit - open
What a list eh?
Any ideas appreciated.
If it’s ah pain it’s going!
Post #560337 Sat Jun 30 2018 7:21pm
Disco_Mikey
CSOV would be the first culprit. Check the air filter for oil contamination Thumbs Up
Post #560354 Sun Jul 01 2018 4:24am
Next question, what's a CSOV ? Laughing. Well I'm sure someone was going to ask.
Answer: Compressor Shut Off Valve. Google LTB00504v3 or LTB00445 might help.
Post #560355 Sun Jul 01 2018 4:49am
Chrisp75
Thanks
Thanks for the reply.
Air filter was spotless.....
I’ll take a look around the CSOV.
Chris
Post #560357 Sun Jul 01 2018 6:11am
htc
United Kingdom 2010 Range Rover Sport TDV8 HSE Buckingham Blue
I'm no expert but the first question I would ask is how old is the battery? These are known to cause all sorts when they are on their way out.
5 years and my battery was toast.
Post #561545 Wed Jul 18 2018 2:17pm
Bladerunner
I had the same symptoms and almost the same fault codes on my RRS.
CSOV was changed but car still faulted above 3000rpm, My Indie then changed some transfer solenoid thing that piggy backs on the primary turbo which was showing intermittent function ET VOILA..................
Car is now running sweet as....
That done along with the turbo oil return pipe modification and i now have a smoke free RRS too.
Post #561561 Wed Jul 18 2018 5:44pm
