Home > Maintenance & Modifications > Oil level check
Oil level check
Hi everyone,
Spotted this while browsing through the workshop manual, hope it can be useful when doing an oil change:
11. CAUTION: Make sure that the vehicle is left for 5 minutes from filling with oil and that the engine oil level is reading at least minimum (by following steps 12 to 20), before starting the engine.
Fill the engine with oil
12. CAUTION: Make sure that the vehicle has been left for 5 minutes from filling with oil.
Start the engine and allow to run for 10 minutes, stop the engine.
Check for leaks.
13. CAUTIONS:
Make sure that the selector lever and the gearshift mechanism are in the park (P) position.
Make sure that the hood is open.
Set the ignition to the ON position.
14. Press the left-hand OK button to access the Instrument Cluster (IC) Main Menu.
15. Press the left hand directional button and select Service Menu.
16. Press the left hand OK button.
17. Press the left-hand directional button to access the Oil Level Display.
18. Press the left hand OK button to access the Oil Level display.
19. CAUTION: Make sure that the hood is open.
Press the speed control cancel button twice within 2 seconds while being on the oil level display.
20. The message center displays the actual oil level in service mode.
Only after having started and run the engine for 10 minutes (as indicated in Step 12), switch off the engine, then stabilizing for 10 minutes, take a reading from the oil level display and, if necessary top up with engine oil.
21. Set the ignition to the OFF position.
22. Allow 10 minutes for the engine oil level to stabilize if there has been additional oil top up.
23. NOTE: The following steps are to update the average oil level value.
24. Repeat steps 13 to 19 to access the oil level display in service mode.
25. NOTE: The actual volume displayed on the bar graph will be written into the electronic control unit as a new value.
Press and hold the speed control cancel button for more than 5 seconds.
The message center displays the current oil level. --
Post #558877 Wed Jun 13 2018 12:31pm
Rich
Bring back the dipstick!
Post #558880 Wed Jun 13 2018 1:21pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
And do not forget to take half a day off Rolling with laughter RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #558882 Wed Jun 13 2018 3:49pm
