![]() | Home > Technical > Fusible link blown. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
you can get them off ebay for example.
Howler Member Since: 07 May 2014 Location: I'm in the Castle. Posts: 29 ![]() ![]() ![]() |
Hi Andy, yes the small square yellow 60amp one, the one that does the compressor circuit. I assume you just pull the old one out like you do a fuse? |
Yes. Called j fuses on eBay |
Its probably blown for a reason. Is the compressor tired and drawing to much current? 2019 5.0 SC SVA (Current)
Thank's Andy.
Better get a couple of fuses.
Ok thanks Andy, I was going to order a few just in case, actually knowing my luck the first one would have popped just to wind me up |
let me know how you get on |
Will do, just ordered x2 of the blighters. |
Hi all, an update to this thread.
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Hi Howler, try Advance factors for the parts they are a forum sponsor and offer a good service.
I don't think hitachi compressors are available anymore? (or costly) so AMK fitted and it required a software update.
Hi PC76 and Andy K, the garage will do the diagnostics on Thursday so I will be in a better position then to know what is needed to be done.
Hi all, further update.
