Home > Faults & Fixes > Suspension, vehicle dynamic and transmission faults.
Howler
England 2005 Range Rover Sport Supercharged Buckingham Blue
Hi every one long time no see!
Well my first major problem since owning this beast Big Cry
RRS supercharged 2005
I have the following faults!
Suspension
C1A27-14 (AF) Compressor circuit - General electrical failure - circuit short to ground or open
( at 198856 km )
Vehicle Dynamic
U0132-87 08 Lost communication with ride level control module - Bus signal/message failure - missing a message
( at 198840 km )
I am unable to clear the fault to engage the ride hight selector and engage the pump!
Am I correct that this is the suspension pump in the boot up the creek? I don't hear it engage any more! I get the yellow light on the dash within a few seconds of starting? I have checked the fuses none blown.
I am also getting this one:
Transmission
P081C-00 (6D) Unknown
( at 198840 km ) any ideas?
Any and all help gratefully received 🖖
Can this be moved to the correct place please, just realised what I've done Whistle
Post #558117 Mon Jun 04 2018 3:49pm
geoffsnook
The compressor is under the car not in the boot Thumbs Up
Post #558118 Mon Jun 04 2018 4:22pm
Howler
Thanks found it. Wink
Post #558191 Tue Jun 05 2018 4:05pm
macellomoto
Italy 2006 Range Rover Sport TDV6 HSE Lux Alaska White
RANGE ROVER SPORT L320 P081C PARK SENSOR
Hello everyone, I have a 2006 sport rr my mistake is the P081C.
I checked the cables on the right side and they are good, I checked the control units behind the battery, I changed the gear selector without success. I checked all the fuses but they are intact.
The car works well but it does not give me the sport and does not show me the gears in the instrumentation display. Can you help me? Has anyone had a similar problem?
Post #574074 Tue Jan 29 2019 7:08pm
