Home > Wheels & Tyres > New wheel nuts |
Hiya and welcome. What was the reason not to use copper grease? Steve. |
Thu May 31 2018 7:14pm |
stevoc Member Since: 08 Apr 2018 Location: Cumbernauld Posts: 22 |
Hi Steve.
Thu May 31 2018 7:21pm |
Thu May 31 2018 7:27pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849 |
The torque loading on wheel nuts is quoted dry, so 140NM in the manual is for dry nuts. You can copper slip between brake hub and wheel a little to stop the wheel corroding with the steel but I never put it on threads. 2019 5.0 SC SVA (Current)
Thu May 31 2018 8:31pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5018 |
I have been doing it for more years than I care to remember and just torqued them up to the recommended torque, on cars, vans, trucks and heavy construction plant and have never had a nut/wheel come loose or seized on, you only need to use a small dab of it.
Thu May 31 2018 8:45pm |
Great advice guys.
Thu May 31 2018 8:51pm |
